Innovate LC1 Wideband Reseting
Posted: Thu Feb 16, 2006 12:17 pm
by qadir03
How often do you guys have to reset? I have the cyberdyne gauge wired with it, and it would get all crazy all of the sudden. I hit my reset button fairly often at least once every couple days. I make sure I do this when I am on overrun and the engine is just pumping air. Once I reset it it reads normal. Is this just me or do you guys also experience the same problem.
Posted: Thu Feb 16, 2006 1:05 pm
by ptegler
I've had two LC-1's flake out completel y in as many
weeks.
I'm fed up.
ptegler
On Thu, 16 Feb 2006 12:17:20 -0800
"qadir03" <
>guys also experience the same problem.1987 Toyota Tercel
>Turbo
http://www.msefi.com/viewtopic.php?t=6276
> _________________________________________________________
> This post is at:
http://www.msefi.com/viewtopic.php?p=102272#102272
Paul Tegler
ptegler@cablespeed.com
Posted by email.
Posted: Thu Feb 16, 2006 2:03 pm
by mk1turbo16v
Interesting.
My LC1 was resetting sometimes when in boost and I thought it was the sensor overheating. Then I lost coms with the m/s ecu and the guage was showing a com error, all electrical cheks OK. LC1 is now winging its way back across the pond for investigation, only 1 month and about 200 miles old
Steve.
Posted: Thu Feb 16, 2006 3:55 pm
by uberbug
I have had some problems with mine too. It would just be "dead" all the sudden or never start up when the car starts. The red LED was just off completely.
I thought it was a wiring issue so I redid my wiring to the box. No difference.
One thing that I think it might be though is low voltage: my car has a generator (not an alternator) and it is down to around 10v when idling after being off for a few days. Megasquirt is hooked up directly through the battery I believe although I guess I should double-check.
Would 10V cause the LC1 to shut off and turn back on, or not come on at all?
