Fuel pump relay questions
Posted: Thu Feb 09, 2006 12:25 pm
I have just ordered my MS-II (V3 board) unit and am trying to make a wiring diagram for my self so I know what wires to cut. I have a 87' Pontiac Fiero and am planing on cutting out the factory ECU (it does not control my gauges). I was looking at my factory diagrams and the stock ECU gives the fuel pump relay power to turn the pump on.
My question is does MS give the relay Ground or Power to turn the fuel pump on? (in the MS diagrams it looks to be ground)
Can I make it so MS will give either one power or ground?
I want to be able to cut only the wires needed to install MS. I will then go and find a male or female (what ever will plug onto the MS wiring harness) DB37 connector and wire it to the factory ECU pigtail. This way if i have a problem with MS I can simply just unplug the DB37 MS harness and plug in my stock ECU back in. The only problem I see is If they give different signals to the fuel pump relay I will have to make up some kind of switch.
