Massive Flat Spot When Back On The Gas After Gearchange
Posted: Sun Feb 05, 2006 6:38 am
by Ian M
Im running ms2 doing abit of autotuning through a wideband sensor, when i change gear i get a massive flat spot, the afr leans right off to about 19:1, if i switch the ego sensor off its fine, anyone give me any pointers?
Posted: Sun Feb 05, 2006 9:50 am
by Lordprimate
Did you set your AFR table?
if you turn your EGO control off and it stops then that would make me thing AFR table...
I was haveing VE table issues when I finally realized my AFR table was All EFF'd up I turned off the Correction(zero) and it solved that problem...
Check your Accelleration Enrichments as well...
