quick question - is it normal ?
mops
- Experienced Squirter
Have a look on the screenshot attached, just after the vertical line.
is it normal, that on throttle relase (even small decerase), afr's go rich for a moment ?
at higher rpm's, on moderate throttle movement's, my afr's basically go rich off the scale.... for a split of a second. Decel enleanment is active only below 1500rpm's I believe.
on this particular pic, the afr's go to 10.5 on the very slight throttle relase...
aswell on the enrich side... accell enrich provides extra fuel only for 0.2 seconds (can do more of course), after which engine goes lean for a moment.
Just wondering whether it is normal/desires/ego reading error/should i be concerned, etc. ?
ms specs in sig.
bimmersquirt
naprotejay
so, I think what you're seeing is 'normal'?? ;)
mops
i'll review my logs.naprotejay wrote:hmmm not sure if this will help answer, but..... before I installed MSII, I had installed an LC-1/XD-1 . it was interesting to watch the a/f as the stock ecu made adjustments.... one of the things that I noticed is that when letting off the throttle, the a/f's would momentarily go rich, and then off the scale lean. on the other hand, when applying throttle, it would go lean, before it would richen up......
I aswell have some logs of etock ecu with MS2 logging map, rpm and afr via LC-1. I'll have a look and reposrt whats going on.
the other thing I'm thinking it might be just error in sensor readount or something similar... many sudden inrush of gases casues sensor to show rich or lean.... or something...
naprotejay
that's exactly what I noticed with the Denso stock ecu in my mazda (AFAIK it does not do accel enrichments....) - when applying throttle, it would go lean, and usually would take ~2, maybe 3? seconds to richen up and 'stabilize'.....grippo wrote:But even if there was no enrichment shot it would eventually straighten out (provided the motor doesn't die and your ve is properly tuned for the changed map at the higher throttle opening.)
soundsgrippo wrote:We have modeled this in version 2.6 and initial testing with a simulation looks good. What you do is change the fuel whenever map or rpm change in accordance with a user input table which can be tuned. This table is used in a very simple algorithm that provides a smooth fuel change as soon as it sees a change in rpm or map and gradually tapers off the fuel change automatically without requiring a lot of coding. For example it easily takes care of the fact that you need less enrichment for accel that starts at hi rpm than you do starting at low rpm.
mops
i have been datalogging my stock bosch motronic ecu, and all tho it does the same thing, it's much less pronounced...
