First time starting help
blown87
blown87
I have checked resistance through the wiring to MS and am getting 6.5K ohms resistance, which tells me the coolant temp sensor and wiring are ok. So I opened up the MS and checked R7 & R8. Both readings are correct (2.5K & 2.2K respectively). I have checked C6 & C7, they are installed in the correct positions with good solder joints. Can I check the actual capacitance while in the board? I have tried (using jumper wires from the meter to the capacitors) but am getting an out of limit reading on my meter. If one of the capacitors are bad will it skew my coolant temp reading? I ran the car for about 10 minutes and my temp guage was reading right at 200 F, but MS was reading 92F. As I stated before, I want to make sure that my coolant temp readings are correct so that the warm up enrichment is correct.
Fastest95PGT
Also, since you're running in parallel with your stock ECU, are you sharing it's sensors too? If so, do you have R4 and R7 installed on the MS board? If so, I think they are likely the cause for your readings to be wrong.
2003 GSX1300R (Hayabusa)
