Help me design my fuel system, please. :)
Posted: Mon Jan 23, 2006 3:28 pm
My project engine is a Mopar 340 that is bored and stroked to 416 cubic inches. Anticipated HP is in the 475-500 range with peak torque over 500ft-lbs. I will be running 42.5lbs injectors (Lucas 009's) and have a Aeromotive A1000 pump with a A1000-6 Bypass Regulator. I also have the Aeromotive 100 micron pre pump and 10 micron after pump filters
My plan is to use -10AN braided line from the fuel cell sump to the pre pump filter. The two filters will be attached to the pump with short -10AN nipples. This will all be mounted to the chassis underneath the fuel cell. On the output side of the after pump filter I was going to reduce down to -8AN hard line and run that up to the engine compartment. That's where my plan fades away.... and I need your help.
How should I plumb the fuel rails up? Daisy chain them series, or use a Y block and feed them in parallel? What size fuel rail and what size fittings for either scenario? And is the regulator I have okay or should I have gotten one with larger inputs? Is a -6AN line sufficient for the fuel return to the fuel cell?
Now to complicate things further, suppose I want to add nitrous in the future. Would the above fuel system support an additional 200hp shot of nitrous? Would I need to use a second regulator to lower the fuel pressure for the carb-style nitrous plate to 8-10psi? Would something like the Aeromotive 13205 regulator work in this application? Or could I just get smaller fuel jets and run the nitrous plate with the same fuel pressure as the injectors?
