any tips to tune out an off idle stumble?
I've started tuning it, I'm to the point where it runs, I've gone for a short drive, and seem to have some of the basic tuning set.
I'm still fiddling with the AE, but I'm getting closer. There's a couple of problems that I'm struggling with, in order of frustration...:
#1 If I very slowly crack open the throttle from a dead idle (around 950 rpm), the O2 and MAP shoot skyward, RPMs drop, I can often cause it to stall. To start driving from idle I need to blip the throttle to get going.
#2 (I may have this tuned out, but...) Sometimes when I come to a stop, and it seems most frequent when pulling high vacuum (throttle closed, engine braking in low gear), the engine speed will drop past idle before stalling when I go into neutral. This might be gone with the little hollow I put into my map around idle, but I won't know till next weekend.
#3 Sometimes, while cold, the engine will, for no observable reason, suddenly drop idle speed to either stall, or go into cranking mode which often saves it. Then back to idle for a while with no problem, only to repeat a little later. As with #2, this might be gone with the little hollow I put into my map. I'm not using an idle air valve.
Any thoughts/tips?
MS-1, v2.2 main board.
Mike_Robert
-Mike
http://kmnet.demon.co.uk/~arnold/
Arnold
Should there be a jump from the idle zone or a smooth climb to the low vacuum / low rpm part of the map?
Hi Arnold, nice looking setup with the blower! I'd like to try a similar thing some day, but I've got my hands full right now as it is
No pictures yet but I'll grab some and post them as soon as I get a chance.
I did a quick write-up on what I've done: http://www.7builder.com/MGB/mgbfi.html.
I checked out your web site. Nice pictures.
Great idea on using the existing temp sensor on your MGB. If I may suggest you can replace your voltage stabilizer with a solid state stabilizer. They are available on e-bay, or you can build one with a three lead solid state regulator from Radio Shack.
Once I get my MG sorted out I'll change the GM sensor to the existing sensor as well for a cleaner install.
efahl
- Site Admin
Mike,mikesb wrote:Should there be a jump from the idle zone or a smooth climb to the low vacuum / low rpm part of the map?
Tune it so it works, and then you'll know.
To get rid of the off-idle stumble, do what Mike says, but I'd say be way more aggressive than he suggests, do something drastic like double the VE values for the 500-1000 RPM bins from like 65-100 kPa. See if that helps or hurts and then you'll have a couple of good reference points.
Eric
Thanks Eric, point taken - I think I'm starting to get the hang of it. The more fiddling I do the better my own mental model becomes and the more addictive it gets... I'm away this week, yet I'm still tempted to fiddle with the map in anticipation of getting back to the garage on the weekend
