MAF
jonfx4com
MAF
Post by jonfx4com »
With my limited experience I can't see any reason why it should not be possible to remove the MAP sensor and connect up a 0-5V MAF sensor and calibrate fuel on airflow instead of pressure. Am I over simplifying this? It would solve some problems I have with rapid changes of MAP on small throttle position changes on ITB's. Are there any plans for MS2 code to allow this and still have MAP to allow ignition advance control based on pressure.
I note in the INI files there are references to MAP, AlphaN and MAF for fuel computations but there seems to be no MAF functionality in megatune. Is this just a left over from some earlier experiment?
Jon
Jon,
Did you see this:
http://www.msefi.com/viewtopic.php?p=94361#94361
There are a number of MAF threads, if you do a search.
whittlebeast
Post by whittlebeast »
The extra code 026h3 and o29a and later do that now. I ran MAF most of last summer.
see http://megasquirt.sourceforge.net/extra/MAF_Stuff.htm
AW
jonfx4com
Post by jonfx4com »
These will run on MS2?
Jon
whittlebeast
Not on the existing MS2 code The mod would be fairly straight forword but you will have to wait for the CAN software to come online to do it with ms2 code as shipped.
AW
