At 5500rpm, my injector time is ~19ms, and my DC1 is showing 89%.. From 4000 to 5500 it rises linearly from 70ms to 90ms.. All may look correct you think..
However.. I am using 300cc/min injectors.. Theres no, no way it's using 90% fuel (of which the injector is probably hard on anyway!).. For the amount of flow it's running presently, it's only around 170bhp or so. Shouldn't really be using anything more than 200cc/min of fuel! (AFR is correct and confirmed and the car is performing as expected).
I'm running the injectors with 2 squirts + alternating (to kinda simulate sequential flow amounts). So each injector squirts once per cycle. Right.
Technically switching to 2 squirt sync should make things worse as it'll have to consider two open-times instead of one, per cycle.
Okay. I know I need to do some preliminary checks. I need to ensure fuel pressure is raising with boost. I need to make sure i've got fuel pressure a tall. I need to test the basics.
But.. can someone clarify that the DC1 is actually what it says, just incase something occurs when you run alternating squirt, maybe you have to divide the DC by 2 in this scenario. I'm just not sure.
Thanks,
Stu
