Injector Sizing Spreadsheet
whittlebeast
see http://www.ncs-stl.com/fuel/ReqInjectors.xls
Please look close at the following section as it gets a little confusing.
1 for Alternating Pulses or 2 for Simultanious Injection Pulses____1
Injections Per Cycle_____________________________________2
Actual Injections Per Cycle for each Injector__________________2
AW
efahl
- Site Admin
Eric
daxtojeiro
- MegaSquirt Guru
Phil
http://www.replica-cobra.co.uk 5.0L TVR powered Cobra Replica (MSnS-E)
whittlebeast
The real solution is hugly progressive throttle bodies.
AW
daxtojeiro
- MegaSquirt Guru
cheers for that, so at 58MPH its going to be undrivable??
Phil
whittlebeast
old-colt
This program has answered some questions for me and opened up more.
I like the estimated airspeed in the intakes. How hard or accurate would it be to estimate peak intake runner velocity?
This is a great and useful tool.
Charlie,
If it ain't broke, Modify it!
http://ffmsd.com/
http://www.cardomain.com/ID/old-colt
deepnsteep
I think there may need to be an if statement added to the "Actual Injections Per Cycle for each Injector" cell. If I select 2-stroke, simultaneous, and 3 squirts per cycle (3 cylinder), it shows 6 events per cycle. That way, I get like 300 lb/hr injectors..........
It's still pretty suprising how much difference there would be between 3 squirts and one squirt per cycle (if I divide actual injections by 2)......about 23 lb/hr diff! Is that reasonable?
Great tool Andy!
Levi
whittlebeast
With a high reving two stroke, you realy can run out of time real fast.
AW
whittlebeast
see http://www.ncs-stl.com/fuel/ReqInjectors02.xls
Thanks for the help
AW
