Car dies after foot off accelerator
mops
Post by mops »
as I said beofre....
did you try to adjust timing ?
I pretty much fixed my idle issue this weekend by:
1. incerasing timing at map/rpm bins as it is approached idle point - my car idles at 800rpm@40kpa, so abouve rpm and below that map are "approaching idle" points
2. richening a few % around approaching idle aswell
3. my deccel fuel is 100%
4. I allowed a bit more air at idle I decerased timing at idle point to keep the rpm's the same - that manouver made idle alot better and stronger... and I still can idle at 14.7:1 AFR
once i got few values right, idle is really good. there's no rolling to find idle... once i relase the throttle rpm's decerase to idle point and stay there with +-25 rpm
air deccel 150% you are probably flooding the engine.
arnold
Post by arnold »
Thx guys, I run the MS1, no ign control yet, the only way I can get a bit more advance at idle is to reconnect my vacuum advance to the dizzy. I removed that one because I fear detonation (supercharged).
The car is running pretty well, no hesitation or flooding. The cold I have to tackle a bit more and my main problem is the idle. I raised the idle to 1400 rpm, so it won't reach cranking mode.
I'll go and modify the VE values near idle a bit too see if I can improe it and reconnect vac advance
MS1, MT2.25, extra code q2
http://kmnet.demon.co.uk/~arnold/
keithmac
Post by keithmac »
Either running a dashpot or the extra code with an Idle Stability Valve will make your car a lot more reliable at idle, I couldn`t set hot idle below 1200 rpm without the ISV, car would die more often than not coming back down to idle..
I run a super charger and map at idle is in the 60`s.
Squirted VW GTI 16vG60 mk2
arnold
Post by arnold »
keithmac wrote:Either running a dashpot or the extra code with an Idle Stability Valve will make your car a lot more reliable at idle, I couldn`t set hot idle below 1200 rpm without the ISV, car would die more often than not coming back down to idle..
Thanks, what kind of ISV do you use and how is it triggered? Do you use a byepass valve in your setup? I am worried abou my 70 kPa and higher idle MAP readings...
keithmac
Post by keithmac »
I run a 2 wire ISV off a mk2 golf gti 16v, this valve is closed at 0 DC which makes it easier to set up. You have to replace the fidle transistor with a TIP122, that`s the only mod I made to the board (fitted a TIP122 using flyleads and heatsink).
It`s well worth doing, I get factory idle and faultless cold and hot starts, makes it a different car to drive.
arnold
Post by arnold »
Is that with the MS1 with extra code? Or MS2? If I remember well, the MS can only trigger a FIdle valve (on / off), no idle controll as fa as I remember though
MegaScott
Post by MegaScott »
arnold wrote:Is that with the MS1 with extra code? Or MS2? If I remember well, the MS can only trigger a FIdle valve (on / off), no idle controll as fa as I remember though
The MSnS-extra code has both PWM warmup, and closed loop idle. I recommend the "warmup only" for starters. The nice thing about PWM idle is the nice range of adjustability you have to get a nice idle speed. Much better than simple on/off.
The US domestic (older) turbo Fords have a boost controlled diaphram that gives spark advance at vacuum, and spark retard at boost. IMHO much better though to eventually use Megasquirt to control your spark.
