Page 2 of 2
Posted: Thu Aug 17, 2006 11:55 am
by jsmcortina
Yes, that's it. However a few points. With a -2 wheel you cannot use teeth 0 or 1. You need to allow about 10 degrees after the trigger angle to max advance. So 50deg trigger would give 40deg max advance (not enough for most people.)
You might want to use tooth no.35 as trigger A with an 80deg trigger angle.
Posted: Fri Aug 18, 2006 7:17 am
by ares650
http://www.msefi.com/viewtopic.php?t=21665
the weird part is that it won't start with 2-20 trig 50.
Posted: Fri Aug 18, 2006 7:19 am
by ochizon
ares650 wrote:http://www.msefi.com/viewtopic.php?t=21665
I am conviced that we have our initial measurement wrong. James gave his suggestion based on my comment that the tooth 7 is under the VR @tdc. That must be incorrect.
