Car Starts! Dies after 3 sec
T3Bunny
If its dieing after three seconds, this is whats going on. It is always three seconds and no fiddling with settings will effect it. I have tried a bunch of ways to get around this too including creating an rpm signal on EDIS setups. Never managed to get the stock relays to work. Its a better idea to bypass the VW fusebox compleatly on the Fuel Pump control anyways.
She runs!
whittlebeast
AW
Start Run Stall
whittlebeast
AW
Start & Stall
Spark settings are:
Offset: 0
Skip Pulse: 3
Algorithim: 1st High, 2nd Low
Gain: 20%
Next Pulse
Crank: 50%
After Start: 50%
Run: 50%
Input capture: Falling Edge
Cranking Trigger: Trigger Return
Coil Charging: EDIS
Spark Output: Going High(Inverted)
Max Duration: 2.0
Also, the prediction option should be Last Interval, but I don't think using the derivative predictions causes a problem, just unnecessary.
I used settings reccomended in the EDIS MSII manual. Copied below for convience:
In MegaTune, set:
Trigger offset = 10° (this will vary, depending on the wheel/pickup configuration),
Ignition Input Capture to 'Falling Edge',
Cranking Trigger to 'Trigger Return',
Coil Charging Scheme to 'EDIS',
Spark Output to 'Going High (Inverted)'.
I will try your recomendations.
Other things I intend to try include increasing the skip pulses from 3 to 6 and increasing the crank to run taper time from 2 to 4 seconds
Al,Why is everyone using Trigger Return.
This is entirely my fault. It dates from when there were only two options, calculated and trigger return. Some people had reported problems with calculated for the cranking trigger, and trigger return worked better for some reason.
However, that was quite a while ago, and I never updated the documents when the trigger rise option became available. In any case, I have set the docs to have people use 'calculated' for the cranking trigger.
From a code standpoint, based on a quick review, I think the following is going on:
In trigger rise it is firing spark (meaning holding the SAW line low) whenever it gets a tach input. This has nothing to do with the SAW advance signal, nor does EDIS care about SAW during cranking.
In trigger return, things are similar, but when it goes past cranking speed it will reverse polarity of the tach in that it gets from EDIS. This is not good unless the polarity was wrong at the start.
In calculated mode, it will start providing the SAW pulse to EDIS immediately and EDIS should ignore it until it determines it has finished cranking. If this is causing a problem, it would be very easy to inhibit sending the SAW until cranking speed is reached.
