Toyota VAST ignition and MS-II
katok,
As far as I am aware, the toyota igniter used with the VAST system does not control the dwell, it relies on the ECU to do this.
katok
Post by katok »
Lance wrote:katok,
thanks for that information lance.
i'm about to set-up my MS2 to a 4age using JDM igniter.
ivanlau78
Post by ivanlau78 »
katok wrote:
Lance wrote:katok,
any update on your 4age MS2 setup? can you let me know your 4age is 16v or 20v?
katok
Post by katok »
ivanlau78 wrote:
katok wrote:
Lance wrote:katok,
my engine is 16v engine (tvis)
i will start my project in a few weeks from now
ivanlau78
Post by ivanlau78 »
have you start your project?
ivanlau78
Post by ivanlau78 »
Posted by email.
phydeaux
Post by phydeaux »
Are their any advantages to using vast over just driving the coil with the ms2?
Currently I have the NE signal going right in to the ms2's vr circuit and am driving the coil with the vb921. I still have all of the vast stuff sitting in a box somewhere and am at a point in the project where if I want to make a change like this its a good time to do it. I've started and run the engine for a little bit in its current configuration and didn't have any problems but the car's not road worthy so I haven't put any sort of load on it yet. The engine is a 4agze fitted with a 4age distributor that has a 4 tooth NE wheel.
andy
`88 Chevy Nova (ae82)
4A-GZE powered
MSII v2.36 v3 mainboard
... mostly running...
phydeaux
Post by phydeaux »
Are their any advantages to using vast over just driving the coil with the ms2? Currently I have the NE signal going right in to the ms2's vr circuit and am driving the coil with the vb921. I still have all of the vast stuff sitting in a box somewhere and am at a point in the project where if I want to make a change like this its a good time to do it. I've started and run the engine for a little bit in its current configuration and didn't have any problems but the car's not road worthy so I haven't put any sort of load on it yet. The engine is a 4agze fitted with a 4age distributor that has a 4 tooth NE wheel. andy
`88 Chevy Nova (ae82) 4A-GZE powered MSII v2.36 v3 mainboard ... mostly running...
Posted by email.
4A-GZE powered
ivanlau78
Post by ivanlau78 »
phydeaux wrote:Are their any advantages to using vast over just driving the coil with the ms2?
andy
can you post your MSQ file?
which version of ms2 you running? i have problem to take signal from 4 tooth. the signal not stable. 4age NE signal should be 24 tooth, 4 tooth is G1.
i'm trying to do fuel only, but still hard to make the engine idle. not sure what's wrong with injector setting.
phydeaux
Post by phydeaux »
I don't really have a msq file right now. The engine has been started on a very loose setup just to test. It fired and idled after alot of tweaking the vr pots, it takes a while to turn those suckers down, and that was serveral months ago.
The pickup may very well be G1 I don't remember. The distributor came out of an early mk1 mr2, It had a 4 tooth and a single tooth wheel in it. I've yet to run the car for any lenght of time. It idled fine for me with the base settings and req fuel set to what ever the calculator spit out for the gze injectors. I'm in the middle of modifying the harness so I can't power it up and look at the settings. The copy of the msq on my harddrive was lost in a crash.
4A-GZE powered
