Problem Starting Busa engine
whittlebeast
Post by whittlebeast »
The reqfuel realy needs to be set per the calulator and the fuel flow brought up by adjusting the VE table.
Seriously. Load the new 026h8 code and take about one year out of the tuning process. You will fight that old code.
AW
bazzer
Post by bazzer »
OK will load the new code tommorrow :-)
Bazzer
turbo355
Post by turbo355 »
bazzer i was wandering if you have a starting ve table for your turbo busa as piggy back also what hp. and inj.size did you run with it as piggy back thanks
