accell enrichement problems
Bimmerjim®
What I would love to see is someone do a side by side on-car (and maybe on-bench also) comparison of MS1 and MS2 tps and coolant. Then take these curves and convert them to common units and plot them in Excel. The reason for this is that it would really be useful to quantify the noise and maybe figure out where it is coming from. In work I see people cover up noise all the time by filtering it, but you should really understand the source before you do it.
Just to add to this thread, I have a relatively stable function generator supplying the rpm signal on the bench. I have good quality pots for the TPS, CLT, IAT, and EGO inputs. I have a car battery supplying the power, so it's pretty stable. The following are as reported by MegaTune.
With MS-II, the rpm varies by:
±1 rpm, under 3000 rpm,
±2 rpm from 3000 to 6000 rpm,
±3 at 9000 rpm.
The TPS varies by ±0.5%. CLT doesn't vary at all (as an integer). MAP varies by ±0.1 kPa.
With MS-I (and the same test set-up), the rpm varies by:
±50 rpm, under 3000 rpm (less if the generator isn't near the break point),
±100-150 rpm from 3000 to 6000 rpm,
±250 at 9000 rpm.
The TPS doesn't vary at all (though it's being shown in 1.0 steps, rather than the 0.1 of MS-II). CLT doesn't vary at all (as an integer). MAP doesn't vary at all (being shown in 1.0 steps, rather than the 0.1 of MS-II).
There isn't a lot in the datalogs that isn't captured above, the only thing is these are captured at about 20 Hertz, so more variation might have been evident than to my eyes, if it had been present.
Cullen
KC Kansas
403 Olds powered Dodge 3/4-4x4 MSD ign, Holley TBI 1:1, MSnS
440 Dodge 3/4t truck. MSD, Holley TBI progressive, MSII, Staged via TPS. Stepper IAC.
