I had just bought a MSIIV3.0 kit. For instance, I´m still studying the best configuration to use in my car (VW 1.8 turbocharged - 14 PSI of boost).
Here in Brazil (where I live) is quite common to use the configuration I use nowadays: four injectors to feed just the aspirated phase, and an extra injector controller by a piggyback module to feed the pressurized phase (under boost).
I was thinking about using this same configuration (talking about the injectors), but of course without the piggyback module. The advantage of using this extra injector in the pressure line is that it provides kind of a "intercooler effect" in the moisture, especially due to the fuel we use here (alcohol).
I was thinking about using one injector output to drive the four primary injectors, and the other output to drive the extra injector. But I believe that I´ll have some problems with this configuration: I noticed that there´s no way to configure two different kinds of injectors in Megatune, and also there´s no way (at least I haven´t discovered until now...
Do anybody here had already tryed something like this?
Any kind of help would be welcome!
