550cc injectors on a V6... 5.1 required fuel glitchy
calrewire
Post by calrewire »
what your saying is that my 55# injectors on my 1.8t is gonna do this but even worse? say it aint so!!! I wish I could use MS2 but it doesnt have provisions for a wheel decoder. :evil:
SRoss
Post by SRoss »
If your 1.8 is a four cylinder you should be pretty good. That gives you about .45L per cylinder where our 2.5L V6's have 4.167L per cyilinder that requires a lower RF value. However if you have the tiny Mazda 1.8L V6 then your really stuck. You could run two sets of smaller injectors and stage them with MSI.
1994 Ford Probe GT 2.5L, T04B, 550cc, MS2.
1981 Ford Fairmont, 351c, MS1.
calrewire
Post by calrewire »
the more I thought about that the more sense it made. Having smaller displacement PER CYLINDER will cause this not smaller total displacement. I thought I was really screwed, but guess thats not the case. :D
invictus_92
Post by invictus_92 »
rebel2k4 wrote:Did you ever try those settings i sent you?
I would really like to see your setup as I will be installing the 550's and cams soon... if this is straighten out. Much appreciated.
Fastest95PGT
Post by Fastest95PGT »
Unfortunately, I don't think this will ever be "straightened out" due to the limitations of the MS-1 processor speed.
But to go with 550's I'd deal with a richer than normal idle if necessary (winter starting could be a problem though).
1995 Ford Probe GT ~ Megasquirted & Boosted
2003 GSX1300R (Hayabusa)
