Minimum Cranking Voltage?
squirrelgripper
It's been a cold week and my cranking voltage is reading as low as 9 or 10V. I can't get the car to start, or idle. This may sound like a dumb question, but what's the minimum voltage that the injectors will open at?
You should have quite a bit more then that though, if thats a fully charged battery your using, i would consider buying a new larger one.
It should be able to keep 11 (or very close) volts during cranking.
