boosted
charlie31603
boosted
Post by charlie31603 »
Ok. I'm very new to this and don't quit understand everything. My question is this. I have a Starion that is a 4 cylinder turbocharged. And I want to run the megasquirt on a custom mpi and get rid of the factory tbi. I did a search and I think I need a flyback board with low impedence injectors. So is that what I want to use on my engine. I didn't see if they have the size(65lb/hr) I need in high impedence. But I read the low impedence are the ones to use for the boosted vhicles. But I also have to use the flyback board inorder to use the low impedence injectors. Right? I just want to make sure I have everything that I need and it will work for me. This is going to be a daliy driver and is going to be raced every once in awhile. Boost is going to be 15psi for now but could go up to 25psi. Thanks in advance for the help! Adam :-)
78Spit1500Fed
Site Admin
Post by 78Spit1500Fed »
If the injectors are low impedance, you should use the flyback board. If they're not, you'll be fine with the circuit in the PCB.
The impedance of the injector is a function of the injector itself... the induction method (forced or natural) is of no consequense.
-Brian
charlie31603
Ok. I was reding this post http://www.msefi.com/viewtopic.php?t=68 ... =impedence. So I thought it was better to use the low-z injertors. But since I don't see my size in the price range I was going to go low-z anyways. But I just wanted to ask and make sure. Also if I'm going to use these injectors I need the flyback board. So that's just one more thing on my list. Thanks again! Adam :-)
Brains
Post by Brains »
We used a set of Siemens Deka Hi-Z injectors on a T76 turbocharged V8, and they're running quite well. The flow rate at the 4 bar rail pressure is somewhere around 65lb/hr, I believe they're rated 57 or 60lb @ 3 bar.
Memory is failing me :?
Image Image Image
charlie31603
I know bar is boost. But what dose 1 bar mean in psi. Still a little new to forced induction. As far as injectors I was looking at these http://www.racetronix.com/17113814FM.html They seem like a very good price and it's the style I need for my intake. But let me ask you this. Are these going to be to big for a 2.6 liter four cylinder. Even though it has a bigger turbo that will push 600cfm at 15psi. The custom mpi with hard pipes for the intercooler. Custom 2.5 inch exhust. And the complete msd system. I heard if I go too small I run lean and over heat the injectors. But If I go to big I will not be use the injectors right and the spary patern will be crap. I don't know. This is my first fuelinjection car. All I had before were carbs. But I'm on the atkins deit now. lol. So If any one else want's to chime in to help, fill free. Thanks again for the help guys! Adam :-)
Brains
Post by Brains »
1 bar = 14.5 psi. So 3 bar = 43.5 psi, 4 bar = 58 psi
Probably the first thing would be to get an estimate of your fuel requirements. Google for a "brake specific fuel consumption" (BSFC) calculator. Punch in the values for your setup, and you should get a recommended injector size.
Its definitely better to run an injector that's bigger than you need. The caveat is being able to get the car idling smoothly with the small pulse widths necessary at low RPM. I don't think those injectors will pose much of a problem in that regard.
Image Image Image
charlie31603
Ok. I'm lost now. lol. I found a calculator thingy. But I don't know how to use it. I put 65 for the flow rate. And 350 for the brake horsepower. And it came up with 0.18xxxxxxxxxxx. I don't know if that's right. I don't even know if I did it right. And I don't even know what it means. lol. Here's the link http://www.webcalc.net/calc/0756.php. I think i'm in over my head. If you can teach me what I'm doing. That would be sweet. Thanks. Adam :-)
Brains
Post by Brains »
Its not that bad once you get past all the terms and numbers. Still doing the same old thing we did with carbs, just related to new words and digits. :)
Try this link instead: http://www.witchhunter.com/injectorcalc1.htm
Use the 2nd calculator down the page and you'll find the right size injector. A couple notes:
1. Shoot for around 80% max injector duty cycle. Above that they tend to heat up.
2. Shoot for the max flywheel horsepower you intend to hit on this or any near future combos. Buy the parts once :)
3. If the fuel pressure your car runs is different from 3 bar (43.5 psi) you'll want to take the number from this calculator, and enter it into the flow rate calculator at the top of that page.
Image Image Image
charlie31603
Ok. I'm still a little lost. It's this whole BSFC. I still don't know what it is or what I should change it to. Also I don't know what the feul pressure will be at 25psi. Because I don't have the car running. The rest of it I get. 400hp, 4 cylinder and 80% injector duty. If I use the .50 that's on the caculator when you load the page it says 62.xx lb/hr, for the injector. If I use the .60 like it says for the turbo applacations. It gose up to 75 lb/hr I think. I'm just confused. Do they make a BSFC book for dummies. LOL. Thanks again for the help. I'm gettting some of it. Adam :-)
Brains
Post by Brains »
BSFC is simply a measure of fuel usage. For our sake, don't worry about relating it to anything specific -- you just pick a number based on application. Turbo cars should pick something in the .60 range, typically.
Quoted from Edelbrock:
http://www.edelbrock.com/automotive/spo ... ech_1.html
Brake Specific Fuel Consumption
Brake Specific Fuel Consumption is the ratio of fuel consumed (in lbs. per hour) to horsepower produced. This ratio is a direct indicator of how efficiently the engine converts fuel into power. Most factory gasoline type engines run approximately a .50 to .55 Brake Specific Fuel consumption (BSFC) range while a highly efficient normally aspirated race engine operates at approximately a .40-.45 BSFC.
* Most common turbocharged or supercharged engine configurations run in the .55 to .60 BSFC range.
* For Methanol powered applications the BSFC is doubled (i.e. turbo/methanol: 1.10-1.20).
These factors should be considered when sizing & selecting injectors for your particular application.
Image Image Image
