BIG thanks to all who post and PM with additional information. /Marcus
MOTORCYCLE
SUZUKI
Make/Model: GSXR600
Year: -01
Number of Tb:
Inside Diameter: 38mm
Center-Center (left to right from behind):
Overall Length:
Outside Diameter (intake):
Outside Diameter (filter):
Separate casting:
Injector Make/Model:
Flow Rate (45psi/100%):
Fuel Rail Inside Diameter:
Additional Info:
Make/Model: GSXR 600
Year: -02
Number of Tb: 4
Center-Center (left to right from behind): 80-80-80mm
Overall Length: 83mm
Outside Diameter (intake): 44mm
Outside Diameter (filter): 45mm
Separate casting: Yes
Injector Make/Model: Keihin KN4, 0J07 AAA A
Flow Rate (45psi/100%): 240cc/min?, 13Ω
Fuel Rail: Alu casted, Inside diameter 6mm (9mm in the ends)
Additional Info: sec. throttles controlled by ECU.
Make/Model: GSXR 750
Year: -98, -99
Number of Tb: 4
Inside Diameter: 46mm
Overall Length: 91mm
Outside Diameter (intake): 54mm
Outside Diameter (filter): 54mm
Injector Make/Model: Keihin,
Additional Info: No sec. throttles.
Year: 2002
Number of Tb: 4
Inside Diameter: 42mm
Center-Center: 80mm
Overall Length: ???
Outside Diameter (intake): 48mm
Outside Diameter (filter): 52mm
Fuel Rail Inside Diameter: 2.4mm
Make/Model: GSXR750
Year: -06
Number of Tb:
Inside Diameter: 40mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: DL1000 V-Storm
Year: ?
Number of Tb: 2
Inside Diameter: 45mm
Overall Length:
Separate casting:
Additional Info: dual throttle plate
Make/Model: GSXR 1000
Year: -02
Number of Tb: 2
Overall Length:
Separate casting: No (dual Tb´s)
Flow Rate (45psi/100%): 230cc/min
Make/Model: GSXR1000
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Year: -03
Number of Tb: 4
Inside Diameter: Tapers from 50 to 42mm
Overall Length: 90mm
Outside Diameter (filter): 53mm
Additional Info: Pic without secondary butterflies and fuel rail.
Make/Model: GSXR 1300 (Busa)
Year: 1999-2003
Number of Tb: 4
Overall Length:
Additional Info:
Year: pre 2002 ?
Number of Tb: 4
Inside Diameter: 42mm at injector end, tappered from 51mm at air horn end
Outside Diameter (intake): 55mm
Flow Rate (45psi/100%): ?
Fuel Rail Inside Diameter: PA66-G35
Additional Info: no secondary butterfly
KAWASAKI
Make/Model: ZX6R
Year: -02
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: ZX6R 636 B1
Year: 2003
Number of Tb: 2
Center-Center (left to right from behind): 75-75-75mm
Outside Diameter (intake): 52,6mm
Outside Diameter (filter): 50,8mm
Injector Make/Model: BOSCH 280031V
Flow Rate (45psi/100%): 245cc/min
Additional Info:
Make/Model: ZX6R
Year: -05
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: Oval TB´s
Make/Model: GPZ750 Turbo
Year:
Number of Tb:
Inside Diameter: 34mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: Z1000
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: ZX10
Year: -04
Number of Tb:
Inside Diameter: 43mm
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: GPZ1100
Year: 1981-1982
Number of Tb: 4
Center-Center (left to right from behind): 77-97-77mm
Overall Length:
Outside Diameter (intake): 40mm ("serrated")
Outside Diameter (filter): 40mm ("olived")
Flow Rate (36psi/100%): 180-200cc/min, 2,5Ω
Additional Info: Picture is from a -82
Make/Model: GPZ1100
Year: 1983-1984
Number of Tb: 4
Inside Diameter: 35mm
Overall Length:
Additional Info:
Make/Model: ZX12
Year: 2002-2003
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: vier pintle injectors tot 190pk ?
YAMAHA
Make/Model: R6
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: YZF-R6
Year: 2003-2004
Number of Tb: 4
Center-Center (left to right from behind): 72.5-72.5-72.5mm
Overall Length: 95mm
Outside Diameter (intake): 52mm
Outside Diameter (filter): 44mm
Separate casting: Not exactly, but can be cut apart easily (fuel rail)
Injector Make/Model: Nipon, # 250031F
Flow Rate (??? psi/100%): ??? cc/min, 11.7Ω , 12mH
Injector Make/Model: Nipon, # 2500322, type: INP250/4
Flow Rate (??? psi/100%): ??? cc/min, ??? Ω
Additional Info:
Make/Model: R6
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: R6
Year: -05
Number of Tb:
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Make/Model: YZF R1
Year: -04
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info: Primary and secondary butterfly valves, longnose 4 pintle
Make/Model: R1
Year: -04
Number of Tb: 2
Center-Center (left to right from behind): 78-78-78mm
Overall Length:
Additional Info:
Make/Model: YAMAHA FJ1300
Year: 2003-2006 (US) 2001 up others
Number of Tb: 4
Center-Center (left to right from behind): 77-87.5-77mm
Outside Diameter (filter): 46mm
Injector Make/Model: Keihin ??
Flow Rate:
Other: TB made by mikuni, uses a coolant thermowax type warmup system for high idle, no secondairy throttle. This model has 150 BHP and 99 TQ.
HONDA
Make/Model: CBR F4i
Year:
Number of Tb:
Inside Diameter:
Overall Length:
Separate casting:
Additional Info:
Make/Model: RC51
Year: 2000
Number of Tb: 2, 2 injectors per TB
Inside Diameter: 48mm
Center-Center (left to right from behind): 24mm (TB's are not parallel)
Overall Length: approx 40mm
Outside Diameter (intake): 60mm
Outside Diameter (filter): 70mm (not sure how filter fits)
Separate casting: Yes, independent TB's, mounted to linkage bracket. Modification needed of fuel pipe and linkages to change spacing.
Injector Make/Model: ????/????
Flow Rate (XXpsi/100%): XXXcc/min, approx 11Ω , ??mH
Fuel Rail: Alu casted, 1 per injector, joined by solid fuel lines
Additional Info: Has a manual choke mechanism synchronized to both TBs.
Make/Model: CBR600
Year: -03
Number of Tb:
Overall Length:
Separate casting:
Additional Info:
Make/Model: CBR600RR3
Year:
Number of Tb: 2
Inside Diameter: 37mm
Overall Length:
Separate casting:
Additional Info: Injectors mounted in cylinderhead.
Make/Model: CBR600FSi
Year:
Number of Tb: 2
Inside Diameter: 36mm
Overall Length:
Separate casting: No (dual Tb´)
Additional Info:
Make/Model: CBR 929
Year:
Number of Tb: 4
Center-Center (left to right from behind): 80mm-80mm-80mm
Overall Length of casting 70mm
Outside Diameter (intake): 49mm
Outside Diameter (filter): - flat flange for airbox
Separate casting: 2 twin body castings
Injector Make/Model: ?? Marked as OK24 B
Flow Rate (45psi/100%): not sure. RUns at 50psi
Additional Info: produces 150bhp at 11,500rpm from 74x54 929cc. 11:3.1 comp ratio, 10 litre airbox.
Make/Model: CBR900 954 Fireblade
Year: 2003
Number of Tb: 2
Inside Diameter: Tapers from 45-41mm
Overall Length: 77mm
Outside Diameter (intake): 50mm
Injector Make/Model: Denso 12 226 4490 I suspect the 226 is cc/min, as the bike is good for 150hp... 13.3 ohms
Flow Rate (45psi/100%): ?? (Std fuel pressure on bike is 50psi)
Additional Info: Factory couplers need to be used as inside diameter is offset and not a perfect circle.
Make/Model: CBR1000
Year: -04
Number of Tb: 4
Overall Length:
Separate casting:
Flow Rate (45psi/100%): 240-260cc/min at 43psi (unconfirmed)
Additional Info:
Make/Model: CBR1000
Year: -06
Number of Tb: 4
Inside Diameter: 44mm
Overall Length:
Separate casting:
Additional Info:
Make/Model: CBR 1100 Blackbird
Year: ??
Number of Tb: 2
Center-Center (left to right from behind): 85-85-85mm
Overall Length:
Flow Rate (43psi/100%): ~335cc/min, 13Ω
Additional Info:
APRILLIA
Make/Model: RSV mille
Year: -02
Number of Tb: 2
Inside Diameter: 51mm
Overall Length:
Separate casting:
Additional Info:
DUCATI
Make/Model: MONSTER 620ie
Year: -02
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: TWIN VALVE 620, 800-1000
Year: -02
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: S2R 1000
Year: -05
Number of Tb: 2
Overall Length:
Separate casting:
Additional Info:
Make/Model: ST3, ST4
Year: -02
Number of Tb: 2
Inside Diameter: 50mm
Overall Length:
Separate casting:
Additional Info:
TRIUMPH
Make/Model: DAYTONA 995i
Year: ?
Number of Tb: 3
Overall Length:
Separate casting:
Additional Info:
SNOW-MOBILE
ARCTIC CAT
Make/Model: ZR600 Snowmobile
Year: 1998
Number of Tb: 2
Center-Center (left to right from behind): 134.5
Overall Length: 105mm
Flow Rate (XXpsi/100%): XXXcc/min, 2.9Ω , 5.8mH
Additional Info: 2-stroke snowmobile, parallel twin 600cc, 105hp
CAR
BMW
Make/Model: M3 e30
Year: ?
Number of Tb: 4
Overall Length:
Separate casting:
Fuel Rail:
Additional Info:
Modified Tb´s
Suzuki GSXR600-02 on Kawasaki GPZ900R -88 (by Marcus)
Suzuki GSXR750 98-99 on Ford 2.3 litre Escort RS2000 (by Exupturbo)
Suzuki GSXR750 98-99 on Yamaha ZXR1000 Turbo (by Exupturbo)
Kawasaki GPZ1100-82 on Ford 1600CVH (by philhoward)
Suzuki GSXR1000 on ST170 Manifold (by Asad)
Honda CB919 on Imp (by Rootes)
