Accel flickering on runtime at idle
Harv
Accel flikering on runtime at idle
Post by Harv »
I have never been happy with my idle quality. it tends to surge a little, 700 to 1000 rpm. At first I thought my injectors were a little too big for my motor, and were causing the idle surge. It acts like I cant get it lean enough. My motor is a Volvo B20 with a ported head and an IPD torque cam bored 30 over with 4 24 lb injectors running with a Datsun 280z fuel psi reg.
Today, while looking at the runtime display, I noticed the accel light flikering with the surge of the idle. This is happening with no throtle movement at all.
Any ideas?
John
looks just like a Telefunkin u-47!
TT350chevelle
Post by TT350chevelle »
TPS or MAP based accel enrichment? Did you try increasing the V/s threshold so the accel enrichment is less sensitive? What does a datalog show?
Brad J.
Harv
accel flash
Post by Harv »
Thanks for the direction. I'll look into it. I'm still learning.
John
