Microsquirt v3:No rpm signal or lack of.Edis wasted spark,bosch 203 module,
Now i've got another module on its way here so id like to figure out what the settings should be in ts so i won't melt another module down.It seems to me its a mix of different settings and experimenting but all in theory this ignition system should work.And i have a total of 3 ignition channels since i ran a 4.7k resistor on the pin 17 and 28 like its listed on getting that channel to open up to a ignition channel.Now im using the stock lh2.2 VR sensor and everything seems like its working.But without a proper rpm signal the rest of the system will appear dead and yet i get the fuel pumps kicking on with the key on but during cranking i get nothing.But i think its all related to the lack of rpm signal.
I'll post my logs below and my tune file if anyone wants to take a gander at this id greatly appreciate it.I am on my own to a point and in the dark as this type of ignition set up has never been used/or i've never found any info to go off using the bosch 203 module with the ford edis v6 coil pack.I've also had to make my own diagrams on making this system work and everything looks spot on.3 signals from the ecu to the module then to the coil pack everything looks right.
Datalog:
http://s000.tinyupload.com/index.php?fi ... 1335953279
Msq:
http://s000.tinyupload.com/index.php?fi ... 9092698051
Thanks!
Re: Microsquirt v3:No rpm signal or lack of.Edis wasted spark,bosch 203 module,
B&G code has a maximum of 2 spark outputs on a MicroSquirt. The MS2/Extra code allows up to 4 spark outputs, but has a separate forum at MSExtra.com.
So i am guessing i need to update my firmware to something from ms extra perhaps?Hmm.
I'll see what i can find and scoop up.Would make sense since im using the standard updated firmware but id still only be set up for the standard 2 channel when i need a total of 3 channels.
Thanks =D
Edit:I found the ms2 extra firmware updates and ill apply those next time i mess with the car.Hopefully this will steer things in the right direction.
Things are looking up! =D
