3.830 code release
3.830 code release
With the release of Tuner Studio v2.1.22 a new serial command was added that required a change in the 3.820 code. This minor change was made in the current v3.830 release. The ini file is identical except for changing the version signature, so there are no changes in inputs to worry about.
megasquirt-II_v3830.ini
(159.73 KiB) Downloaded 87 times
Monitor_v3.830.abs.zip
(49.71 KiB) Downloaded 93 times
fabio.silva
Re: 3.830 code release
Post by fabio.silva »
Hi grippo,
I updated the Microsquirt V3 to 3.830 code release and now the fuel pump "start and stop" continuously. Whats happen?
Thanks!
Fabio,
You probably need to set the ECU type. For more info, see the red text here: http://www.useasydocs.com/details/usv3code.htm
fabio.silva
Hi Lance,
That's right.
Thank you!
Towelie
Post by Towelie »
I updated the firmware on my us v3 today to 3.83, but it came up with ini mismatch warning! I used the downloads off the microsquirt quickstart link. its saying that the ecu is 3.78 and the ini file is the 3.83. I set the ECU type and there are no errors now.
It seems to work, although I have not put the engine in yet to check.
Is it possible that the s19 file I downloaded is an older version? I also have no launch control or flat shift in tunerstudio now? Were these removed?
If you loaded the code above in this thread it should match the ini file you selected. I don't know if this has been propagated to the Quick Start link yet, but if not it should say there what version you are loading.
However, if you want launch control and flat shift you have to use extra code and the extra ini file that goes with it. TS only provides the input and output interface for what is in the code that you load in the ECU. If you are going to use extra code you need to read and follow that documentation and ask questions on that forum.
