Snowmobile project. Questions before ordering microsquirt.
classic-indy
I plan on installing at the minimum a Tachometer and O2 gauge. Once I've installed the gauges I would then dial in the jetting so that I know what Air-Fuel ratio to aim for once I convert the sled over to EFI.
My question: Will a narrow band O2 gauge do what I need for tuning, or should I get a wide band O2 gauge?
- Master Squirter
Two stroke AFRs
Obviously, two stroke oil will affect your sensors' sensitivity with time, but reading your post you talk about carbs and jetting, so are you using the Microsquirt for ignition only
EDIT, OK I get it now, you're looking at grabbing the AFR info from your carbed engine, and applying this to your EFI AFR table modelling. I wouldn't bother just look at the AFR targets for a four stroke. Bear in mind too you'll need a richer start to get the engine running from cold (affects WUE etc), and that target AFR will be lower than the four stroke set up, as this is actually a little higher in reality, because the oil "dilutes" the available fuel by the ratio mix. Simplistically, if you were seeing for 14.7 on your gauge you would be running approx. 3-4% weaker.
PS I always took the head off and looked at my engines for detonation/richness etc. One of the nice things about two strokes, was simpler cylinder head removal.
classic-indy
Re: Snowmobile project. Questions before ordering microsquir
Also, do I have to run a battery to run the Microsquirt ecu or can I get around using a battery? This is not a life or death but the sled doesn't have elec start, and I was thinking if I can get around using a battery it would be nice.
I think you'll need a small battery.
classic-indy
