Different temp exhaust ?
Norzilla
Post by Norzilla »
Hi All
I think this might be a simple question?
I have the front and rear cyl of my V-twin running different exhaust temps.
The front at idle is 250 deg C
The rear at idle is 200 deg C
Does this mean that the front is running lean or rich?
I only an WB O2 in the rear pipe and it is stable at about 13:1 AFR at Idle
Re: Different temp exhaust ?
Maybe somebody here will know, but I thought EGT peaked at stoich, and fell either side of it, in normal running conditions.
PS I have seen if it gets too hot aka 600 degC two stroke exhaust when you're going well lean, and detonation is just around the corner.
racingmini_mtl
Post by racingmini_mtl »
Ignition timing will also affect EGT.
Jean
