us Failure?
us Failure?
I have absolutely no clue why this happened. We loaded some settings from an msq (with inverted trigger enabled, I checked), rebooted, and started cranking. It was working 100% the previous night. I then played with a scope and noticed that MS is not issuing spark commands- the pin 1 on each VB921 is stuck at 5/0V when we switch to and from inverted output. Everything else behaves normally. I even put the Extra firmware on to use the output test mode, to no avail. The spark drivers also acted funny, sometimes one being on and the other off at 0 RPM. Everything but the spark works 100%. I may have misread the scope, but it seems the problem is with the MCU, the spark drivers work fine and flow current when on.
Any ideas? Did I fry the MCU somehow?
