went to a cycle salvage today.Got a FP and a coil. both are small and the pump is rated at 50 psi . I looked at the TB's they had and the injectors are small, perfect for my app.., most of them had too high a flow rate, although the cbr 600 injectors might work.
They wanted to sell the entire TB, more than what I need. SO the injector search continues.
You'll have to remove attachments from your old posts to clear up space once you reach the limit. The easiest way to find and delete old attachments is to search for your own posts.
or do a search on image optimizer. This will allow you post a lot more pics without exceeding the limit, and also greatly speeds up download times for those of us on dial-up!
it's a pump out of a street bike, not sure what bike. It's small, 3.5" long by 1.25" in dia.
I am Microsing a 32hp generac motor for a boat.
I heard that the injectors off a CBR might work since there are two per. cyl.. I found some injectors off a O.B. motor that have the flow I was looking for.
i have a pump just like that on my VFR and im almost willing to bet that it will NOT be an efi pressure pump. did hte bike you got it off of have carbs?
