Ignition Map Configurator
boost junkie
Post by boost junkie »
Yeah, 5 degrees is very retarded. Honestl I wouldn't even mess with a timing calculator. Way too many variables. Just tune for detonation threshold until you can put it on a dyno. Then tune for the min timing that produces the best torque (often referred to as MBT).
-shawn
msns-e controled turbo neon
sample msq's!
JakobM
Post by JakobM »
New beta version uploaded with corrections for > 3valves engines.
JakobM
Post by JakobM »
boost junkie wrote:Yeah, 5 degrees is very retarded. Honestl I wouldn't even mess with a timing calculator. Way too many variables. Just tune for detonation threshold until you can put it on a dyno. Then tune for the min timing that produces the best torque (often referred to as MBT).
I agree that it is not possible to make any 100% pre-configurated map as the variables are crossing each other in too many ways. Calculating MBT = not possible, just like finding peak pressure / max tourge area and setting(retard) MBT after this. Setting an ignition right is not for any calculator.
Having this in mind the goal of this configurator is to give an estimated ignition map as a start-up map, based on the factors Valves/cyll., CR, Octan, Temperature, Squish and water injection.
bens_cab
hmm
Post by bens_cab »
hi my max pressure is 250kpa
VW Mk1 Golf Gti Cab 20v turbo msns extra 029q2 v3
JakobM
Post by JakobM »
Jon k wrote:My generated map looks a little funky - its telling me to run 5 degrees of advance at 180 kpa
4v per cyl
10.0:1 cr
<88mm
95 oct
Average temp
Squish 4v
no WI
5 degrees is very retarded isnt it?
You are going forced induction with CR 10:1 This is not the best CR more like the N/A way. Plus you are average air cooling and 95 octan fuel. However, som corrections had to be made and a new version has now been uploaded with corrections to 4 and 5 valves heads.
If you to day are going 180 kpa with 10:1 in CR I would very much like to see your ignition map. Thanks in advance :)
Jon k
Post by Jon k »
4v per cyl
10.0:1 cr
<88mm
95 oct
Average temp
Squish 4v
no WI
I am running only 9.5 psi intercooled. I put 95 RON in there because I figured it would create the safest map.
BMW M50 Non Vanos 24v 2.5L Turbo
MS-1 V3 running fuel and spark on MSnS-E 029s
JakobM
Re: hmm
Post by JakobM »
bens_cab wrote:hi my max pressure is 250kpa
Thanks alot :)
JakobM
Post by JakobM »
Jon k wrote:
4v per cyl
10.0:1 cr
<88mm
95 oct
Average temp
Squish 4v
no WI
Tanks alot :) Ok, so you are running 165,5 Kpa intercooled with CR 10:1 - Do you have any current ignition map you could poste or just inform about max advance at your 165,5 Kpa / 9,5 psi. It would give valuable information about high CR under medium/low boost. (all asuming that no pinging is present)
Jon k
Post by Jon k »
JakobM wrote:
Jon k wrote:
JakobM wrote: You are going forced induction with CR 10:1 This is not the best CR more like the N/A way. Plus you are average air cooling and 95 octan fuel. However, som corrections had to be made and a new version has now been uploaded with corrections to 4 and 5 valves heads.
I don't have my map on hand because my laptop battery is dead, I am at home from school (leaving in like an hour!!) and I have no power plug for laptop. BUT I do know that I have my max advance @ 100kpa of about 19 or 20 degrees and as soon as I hit boost, I drop down to 12 advance flat. Its a horrible tune I know, but its working for now.
thedge
Post by thedge »
I havent used it on my car yet (gouged out cylinder wall....) but I do have one suggestion. Is there any way that you can specify how many RPM points? MS uses 12, so if there was an option to select how many that would be quite spiffy 8) And the other one I just thought of, perhaps a link to a homepage for the spreadsheet, so that people can make sure they have the latest version? Can probably just be a folder, nothing fancy. Other than that it seems great!
1986 Porsche 944 Turbo
Cylinder head work (8.5:1CR, race springs, ported, oringed), Ceramic'd exhaust, crank scraper, race clutch bits, stiff sway bars, and more.
