Can the settings be wrong, but the timing sync?
trigger 1- tooth 7
trigger 2- tooth 25
trigger angle - 70 degrees
With these settings, the timing synced up, but when driving the car, something is off, and I dont think its the timing map so much as an error of mine in the above setup.
To simplify, what I want to know is can you have more than one trigger/trigger angle combo that will seem to give properly synced timing, but only one that is actually correct? Or is there only one setting that will sync up?
jsmcortina
- MegaSquirt Guru
It is very important to confirm timing with a strobe.
In my previous post when I wrote that I got it to sync, I meant with a timing strobe. I just wonder if there are settings that will sync up with a strobe, and yet not be the right settings, since I got it to sync with a strobe but feel that its not right. I ask so that if there is ONLY ONE way to get it to sync, then I know I have this part done correctly, and need to look elsewhere to solve my issues.jsmcortina wrote:All the wheel needs is the missing tooth to get sync and correctly spaced trigger numbers to get stable rpm. However the timing can be TOTALLY WRONG !
Honestly, I am failing to understand clearly the relationship between the trigger points, and the trigger angle. I can see that they are integrally related, but I am not sure what the relation needs to be.
jsmcortina
- MegaSquirt Guru
If you mean that you verified the indicated timing in Megatune matches the actual timing at the crank then that is good. Check over various rpms and advances and make sure it always matches. Once you have that sorted it is a case of tuning.
The base spark table provided is intended to be "lame" and fairly safe.
With your trigger A at tooth no. 7 you are saying to the code "when you reach tooth no. 7 you are at 70 BTDC for (that) cylinder"
Likewise with your trigger A at tooth no. 25 you are saying to the code "when you reach tooth no. 25 you are at 70 BTDC for (that) cylinder"
ok, you may be helping me get somewhere here.jsmcortina wrote: With your trigger A at tooth no. 7 you are saying to the code "when you reach tooth no. 7 you are at 70 BTDC for (that) cylinder"
you say when I set trigger A to tooth 7, I am telling the code "70 BTDC?"
I thought I was telling the code "you are at TDC now"
in real terms, so that you know, my tooth seven is what is sitting in front of the VR sensor when the engine is at TDC.
CAn you tell that I am a bit lost? hahaha
jsmcortina
- MegaSquirt Guru
Yes, it uses 70BTDC because that is the number you entered in Trigger Angle.ochizon wrote:you say when I set trigger A to tooth 7, I am telling the code "70 BTDC?"
What happens is the code counts the teeth until the tooth number matches the numbers you entered. Then it goes to the normal ignition code (as if it got a signal from a dizzy) it uses the number you enter into the trigger angle as the current position and works out the delay to the spark.
Is this really a 36-2? If it is the common 36-1 then try using trigger A = 1, trigger B = 19 and trigger angle = 60.
IF it is a 36-2 then try using trigger A = 2, trigger B = 20 and trigger angle = 50.
jsmcortina
- MegaSquirt Guru
If the commanded advance was say 14 deg and you had a 60 deg trigger angle it will work out that the delay needs to be 60-14 = 46 degrees.
It then works out how long in microseconds 46 degrees is and sets the delay timer for the spark.
If you set a 50 deg trigger angle it would wait 36 degrees.
the trigger angle is the headreoom for max advance AFTER the trigger signals!!!
So with a trigger angle of 50 degrees, I can run advance upto 49 degrees, one degree after the trigger.
If I were to sete the triggers at 1 and 19, I could set the trigger angle to 60 degrees. At 3 and 21, 40 degrees...
minor adjments are made to the trigger angle to get proper timing with the strobe.
I was noticing a wierd timing because I was probably severely out of phase with my settings....
I CANT WAIT TO GET TO MY TRUCK!!!!!
