mustang tfi/msd no spark output need help please
the car will not start, getting fuel, but no spark
the crane hi-6r I'm running has a status led that says - power supply fault on initial startup
the screen when ignition on and starting shows rpm and pulsewidth to be 0, both stay pink
where should I start, please help, been too long since hearing it run
TV Super Bee
383 EFI dual 65mm throttle bodies, 36lb injectors
"AS SEEN ON TV"
http://www.moparalley.org/gallery/hollywood
jsmcortina
- MegaSquirt Guru
http://megasquirt.sourceforge.net/extra/setup-tfi.html
The output side mods are badly described at present. I'll update them soon.
jsmcortina
- MegaSquirt Guru
What about the specified 330ohm resistor to 12v?95roush wrote:when I hooked up the led 17 circuit, I simply put a wire from the neg side of the led, and went to pin 36 on the db37.
If the PIP wire touched the shielding you would get no rpm.the input is tapped into the pip on hte tfi. now if the pip wire is touching hte shielding at all, will this cause me some problems?
Did you do the board mods exactly as the instructions?
