PWM
2713ddddavid
PWM
LED go from dim to bright in response to coolant teemperature changes. If I have it set for "closed loop" instead of "warmup" the FIdle LED only blinks off for about one second then on for a couple of seconds no matter where the coolant temp is. Ive tried this in the car as well but no idle control in closedloop. I want this to control idle in closed loop as my warmup idle is controlled by a seperate control (thermowax) I know the BAC valve good cause it works fine with the stock ECU.
My car is a 1986 Mazda RX7, none turbo, bone stock except for the MS and the LC1 wideband. I`m also having trouble getting Autotune to work....................but thats another post I`ll put up after I get this problem solved.
TIA
2713ddddavid
