Tuning at WOT
PortbluePGT
Tuning at WOT
Post by PortbluePGT »
Car is 1994 Ford Probe GT(N/A). I am tryin to get my A/F at 13.2 or so at WOT. I am Using MSnS-E, with 024s13 and MT2.25b717. I am pretty sure that I am not in open loop mode. I am using Target AFR with a LC-1 WB and XD-1 Gauge. I have just started using Autotune also. I actually went in and manually adjusted the Fuel table in that area of the map and it still runs in the mid to low 12s at WOT.
Any suggestions?
-Donny[/quote]
Getting Prepared for Boost
Mike_Robert
Post by Mike_Robert »
Lower the numbers in the bins where you're too rich by 3-4 and see what that does. Also, you are burning any changes you (or autotune) make, correct? The msq and datalog posted would be nice as well....
-Mike
PortbluePGT
Mike_Robert wrote:Lower the numbers in the bins where you're too rich by 3-4 and see what that does. Also, you are burning any changes you (or autotune) make, correct? The msq and datalog posted would be nice as well....
-Mike
Mike, I will lower the numbers and see where that gets me. I was letting Autotune make changes but I was burning them to the controller. I will post an Msq later but I don't have a datalog. The Laptop I have does not have excel and I cant seem to get it loaded on the hd.
Thanks for the reply
-Donny
