LS1 ignition
shortbed454
LS1 ignition
jsmcortina
- MegaSquirt Guru
http://megasquirt.sourceforge.net/extra
you could run those coils in a "wasted COP" arrangement. The coils are "logic level" which means they don't need a high current ignition driver chip to drive them.
The LS1 trigger disc is pretty odd, so you would be better fitting a standard wheel such as a 36-1. A number of aftermarket companies sell LS1 conversions to use these wheels in order to use Megasquirt and other ECUs.
I am unsure whether anyone has tried to do exactly this yet, but see no reason why it should not work.
eliotmansfield
LS1 ignition
Fitting a wheel to the damper cannot be done unless you have a woodruff key fitted to the crank and damper - which would entail removing the crank - so you might as well replace the GM wheel with a 36-1 anyway.
Â
I think the day that someone figures how to decode that GM wheel, will see a another big increase of megasquirt users, as the LS1 seems to be becoming the engine of choice for upgrades.
Â
Posted by email.
shortbed454
key
jsmcortina
- MegaSquirt Guru
Both Eliot and I were somehow on the wrong track... You told us that you have a 454 then I start answering as if you have an LS1 ! Oops.
You might think that there is some movement because of the rubber ,
but if you research into what the damper is designed to damp you will
find that they are very high frequencies , around 5 to 7000 hz ,
the amount of actual movement is on the order of .1 degrees .
The difference between EDIS and the stock dizzy as far as
spark scatter is concerned is a night and day difference ,
the dizzy had as much as 4 degrees of scatter ,
the EDIS is rock solid stable , no discernable scatter at all .
...................Jim
shortbed454
jsmcortina
- MegaSquirt Guru
Once the trigger wheel and VR sensor are done the rest of EDIS is just wiring.
See:
http://megasquirt.sourceforge.net/extra ... uneed.html
and also the links at the top for an MS1/Extra slant on things.
eliotmansfield
Also consider that it's known for the outside to shift considerably over time. Been working with matts tvr/rover v8, his outer damper (and hence the timing marks) were out by around 70 degrees!jsmcortina wrote:Make sure that your trigger wheel is attached to the centre of the damper not outside the elastomer part or it will give somewhat erratic timing.
I remarked my damper 3 years ago. Soon, when I fit a wheel to inner(!), I will re-check and see if its shifted since then.
