Just wired up everything today, calibrated the TPS without any problem, but when I try to calibrate the CLT / IAT sensors it doesn't work !
When it says "Downloading entry xxx" it suddenly stops around entry 600 and doesn't change anything at all ...
BIAS resistors are 2490ohm, PCB V3, MS-2 running fuel and ignition (TFI), car is a VW Fox Wagon with FIC EEC system (with Megascott's board).
Shall I change the BIAS resistor for new ones with bigger resistance ?
Cheers
Daniel
