Setup of duty cycle required ????
quattrodave
Post by quattrodave »
Hiya guys,
I've just got my first MS running and i have a few questions...
In the configuration and tuning guides it says :-
"You want this to be set so that your idle pulse width is no less than 2.0 ms, if possible, and your Req_Fuel is less than 15-18 milliseconds, but more than 8 milliseconds."
Currently my idle pulse is 1.8 ms and my required fuel is 5.1.
I need the big injectors as alot of boost is being run.
How do i get these figures within specification ???
Many thanks
Dave
TT350chevelle
Post by TT350chevelle »
The key word is "if possible" when you run large injectors for big power you may not beable to reach the recommend settings.Are you running a boost/manifold referenced reg? This also helps injector PW by reducing fuel pressure when idling.
Are you able to get a decent idle? If everything is running OK, don't worry about it.
Brad J.
quattrodave,
In additions to Brad's excellent advice (as usual!), the req_fuel size issue is less important with MegaSquirt-II, because of it's much finer pulse width resolution (100x better than MS-I).
So, to second Brad's advice, don't worry about it.
boost junkie
Post by boost junkie »
Mines worse. 2000cc engine with 780cc injectors. Idle pulse width is about 1.5ms. I sure with I had the 0.001 resolution. Can't wait for MS-II 'extra'. 8)
-shawn
msns-e controled turbo neon
sample msq's!
quattrodave
OK.... In that case the question arises, How do i get a solid basic tune at idle whan changing figures around make little difference....??
Many Thanks
Dave
