GM DIS questions
flyguyeddy
GM DIS questions
I piggy-backed the VR sensor and wired in the OBDII module into the fenderwell with no coils hooked up to it and the ref pulse low and hi not attatched as well. (the ref pulse low and hi for the older module are wired into the ECU, so it should be seeing rotation).
should i make a resistor pack to simulate coils?
should i remove the ref pulse signals from the older module and replace them with the OBDII module? will that mess up my ignition advance signal to the current module?
hopefully you gm dis people can help me out with this
wopontour, any suggestions?
Brandon
codebase and megatune version shouldnt have any effect on any of this, however i am running the latest megatune, MSII version 2.3 (i think) and the V3 board.
bluetrepidation
- Experienced Squirter
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
flyguyeddy
it is. the wire colors are the same on the two years of connectors i have.bluetrepidation wrote:I'd make sure your VR sensor's polarity is correct to the ICM.
A.J.
they are.bluetrepidation wrote:. Make sure the grounds are good.
A.J.
it does. stock wiring used on the engine, just stole certain wires from the ecu.bluetrepidation wrote: One should go directly to the ECU.
A.J.
I'm trying to get the tach to work and get the ECU to control the idle speed motor. it is not seeing revolutions. do i have to have teh injector circuit hooked to something? right now i just have the injector leads cut and wired to the MS.bluetrepidation wrote: Besides that I'm not sure what your trying to ask?
A.J.
flyguyeddy
flyguyeddy
yes, the rpm's work in megatune. its not a matter of the megasquirt not getting a tach signal, its a matter of telling the factory computer that the engine is rotating. when that happens the tach will work and the idle motor will work.
let me repeat: the factory ecu is NOT seeing engine rotation for some reason or another. will my previous ideas work? anyone know?
flyguyeddy
flyguyeddy
