popping on deceleration?
anarchyx34
Post by anarchyx34 »
I'm posting this in the general forum because I'm not sure if it's a fuel or ignition problem. Mods please move it to where you feel it belongs.
Anyway. I'm experiencing popping from the exhaust on deceleration/engine braking. I do notice that my AFR guage drops to full lean when I let off the gas, so I cant see it being unburnt fuel, and I've toyed with the over-run fuel cut and it didnt make a difference. What could be causing this?
'90 Mazda 626 turbo. FE3-T DOHC engine swap running on MSNS-E. v024, v2.2 board.
'92 VW Jetta GL- Turbodiesel swap
Toady
Post by Toady »
holes in the front part of the exhaust and small amounts of unburnt fuel... probably a combination of the two.
Toady
'97 UK Spec Ford Probe 16v
Mazda FS 2.0 16v Engine
Soon to be Squired !
anarchyx34
Actually I did suspect the exhaust at first since I was running and open downpipe. But now I'm running a complete exhaust, cat converter and everything with no leaks. It probably is unburnt fuel, but how do I eliminate it?
Poweredquest
Post by Poweredquest »
I take you have heard rigs jake brake (engine braking)?
If so, then that is effectively what you are doing.
Every manual that people do it with, do it. There is no getting around it.
It is not neccesarily unburned fuel, but the high RPM engine operation with absolute minimal fuel.
Under hard acceleration and then sudden let off can cause unburned fuel popping (which with an open exhaust) usually produce a fireball out the tail pipe. RX's with a good exhaust system are famous for it.
snillet
Post by snillet »
Old carbed cars can do that frantically...
I had a Mini once with a freightened 1400cc engine and the exhaust going straight back from the header into a 2.5 inch full flow "damper".
At night you could almost think there was lightning behind the car when you revved it and changed gear :lol: , i think it´s quite cool really :!:
Peugeot/Citroen XU5 BDZ(4cyl 1.6litre) engine with 60-2 VR wheel decoding singel coil and dizzy spark and Magneti Marelli(solex) TBI. Msns-E hi-res 0.08f and E85(Ethanol) in the gastank.
kanenas
Post by kanenas »
leaking injectors can also feed extra fuel into the system. have you run datalogs?
anarchyx34
I havent run datalogs yet. This isnt happening from hard acceleration. I can be cruising at light load and just let off the gas and it does it.
zguy36
Post by zguy36 »
Add some fuel during the decel andI bet your poping goes away. This is just how an engine sounds at high rpm with very lean mixtures
2WHEELENGR
Post by 2WHEELENGR »
I think zguy36 is right. Set the decel amount higher in the Acceleration Wizard. :D
Everything COUNTS when you're racing the CLOCK!
2WHEELENGR.com
Karl_Skewes
Post by Karl_Skewes »
we used to find this before we overrun was available in the extra code.
basically the bottom row on the VE table was 0, but injector opening times or whatever caused some fuel to go in and it would pop consistently.
as said above, adding a bit of fuel to that bottom row and it went away... it was pretty cool though (combined with some AE could make consistent flames)
