MSII v3 - Running wideband, wierd Lambda readings
(Excuse the fact I haven't experimented enough, all the time I had to spend tuning was spent trying to figure out how to program the stepper IACV, of which I ended up giving up on as the algorithims seem to make no sense. After logging on this forum, I realized I'm not the only one. I suppose I'll give it one more shot and until then it'll be easier to just go to back to an ICV)
Thanks for the help!
bluetrepidation
- Experienced Squirter
Set it to: Innovate LC1 0-5
As far as I understand it you must reprogram the stock LC1 to output 0-5 volts for 10-20 AFR for whatever output your using. Just run the programmer that came with it.
If you want Megatune to display AFR you need to set that in the configurator I believe.
A.J.
V3 PCB
MegaTune 2.25
Innovate LC1 WB O2 Sensor
OBD I Saturn Wasted Spark DIS
w/ Cooling Fan and IAC
