MAP not stable under boost?:
BraneDeadx
so far it seems when im pushing around 16~18 psi of boost my car will make some wierd hesitation and hissing noise... at first i thought it was my blow off valve being opened from the boost, but i added washers that came with it to give it more spring tensition and that seemed not make a noticeable difference....
when checking my logs i notice the map single is real spikey.... im running the anti lag filter at 60% to help smooth it out but it is still very spikey, and when looking at it u can see the pulsewidth fallow the map makeing my AFR little bit jumpy..... what can i do to smooth this out? im afread to add to much lag filter % and make it harder for MS to see the real mao varations..... i dont know why id be seeing this kind problem
anyone got any thoughts? im runnig MS2.53 V3 board EDIS4
Sean..
The default lag on MAP is 50%, this is more smoothing than you currently have at 60% (higher numbers mean less filtering, up to 100%=no filtering).
I would think you should try values around 30% to 40%, that should smooth out the MAP signal without affecting the response terribly. You can go even lower, depending on how it affects your particular engine.
There's more on this here: http://www.megasquirt.info/ms2/configure.htm#lag
