need sample itb msq
metcap
need sample itb msq
Post by metcap »
I'm on MSII with V3 board running daughter board, package is controlling my 1800cc itb engine. I've done some tuning for the last 2 weekends and am happy to be able to get the engine started and idling quite good except for map fluctuation so I'm planning to add a restrictor on the line. My problem is that I'm having trouble getting the acceleration correct. I've stumbles with fast throttle openings and sometimes intake backfires. Does anybody have a sample of msq file running a itb engine so I can at least get an idea what should be done, thanx. I'll post my datalog and please have a look through.
tkm
WolfGTI
Post by WolfGTI »
Here's my MSQ from my 2.0 L VW - running ITB's. Code version is 029i.
MSnS-E, V2.2, MT2.25
metcap
Post by metcap »
Wolf GTI, thanx a lot. Do you know if this file will work on MSII V3 mt2.25?
tkm
WolfGTI
Post by WolfGTI »
This file is for MSnS-E - the fuel table and spark table can be exported but the rest of the settings will have to be entered in..
metcap
Post by metcap »
how do I access these information using MSII mt2.25? I tried opening the file but it keeps giving me errors and I'm back with my earlier settings.
tkm
Karl_Skewes
Post by Karl_Skewes »
I have some VEX Tables up which may be more suitable.
Check out - http://www.garagedori.com/tech
Scroll down to megasquirt configs...
Come to think of it, my MS-II ITB setup should be on there.
metcap
Post by metcap »
karl, thanx for the help...I'll take a look at the values there and see how it works out for my set up.
tkm
